 how use top2048
sdow Posted - 12/20/2006 : 21:55:35
I bought Top2048, can you explain me how to program my PIc16F877
sdow Posted - 12/24/2006 : 16:13:55
can you help me. I use pic16f628 i would blank my led. can you help what i need to do in confgiration to blink my led .
; Processor: PIC16F628 at 4 MHz using internal RC oscillator
; Function: Flash a LED connected to RA2
; Hardware: Testboard K4
; Filename: 628LED.asm
; Author: Lars Petersen, oz1bxm@qsl.net
; Website: www.qsl.net/oz1bxm/PIC/pic.htm
; Credit: Tony Nixon's LED flasher
LIST P=16F628, R=DEC ; Use the PIC16F628 and decimal system
#include "P16F628.INC" ; Include header file
__config _INTRC_OSC_NOCLKOUT & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
CBLOCK 0x20 ; Declare variable addresses starting at 0x20
Loop1,Loop2
ENDC
; INITIALIZE
ORG 0x000 ; Program starts at 0x000
CLRF PORTA ; Initialize port A
CLRF PORTB ; Initialize port B
BSF STATUS,RP0 ; RAM bank 1
CLRF TRISA ; All pins port A output
CLRF TRISB ; All pins port B output
BCF STATUS,RP0 ; RAM bank 0
; FUNCTION OF PORT A PINS
MOVLW 7
MOVWF CMCON ; Comparators off, all pins digital I/O
; MAIN LOOP
Main BSF PORTA,2 ; Turn on LED connected to RA2
CALL delay
BCF PORTA,2 ; Turn off LED connected to RA2
CALL delay
GOTO Main
; DELAY 250 MSEC
delay MOVLW 250
MOVWF Loop1
Outer MOVLW 200
MOVWF Loop2
Inner NOP
NOP
DECFSZ Loop2,F
GOTO Inner ; Inner loop = 5 usec.
DECFSZ Loop1,F
GOTO Outer
RETURN
END
ZLM Posted - 12/24/2006 : 02:51:07
Originally posted by sdow
hi
can you help me . I have one problem every time,I have a error :Typr error. What is that?
Possible reasons:
1. incorrect device type selected.
2. chip is placed in a wrong position in ZIF socket.
3. contact issue of your chip's pin.
sdow Posted - 12/23/2006 : 14:57:26
hi
sdow Posted - 12/22/2006 : 12:36:39
Hi
Can you help me. I would like to flicker my led. But I am not able to use the software. can you help me.
