 can not get my pcb5.0e-2019 to work
fc227a Posted - 03/15/2020 : 06:37:43
greetings all,
I have a pcb5.0E-2019 I can not get to work. I suspect it is a communications issue. I have tried different LPT port settings. Can not get it to respond . the program load and starts but when I go to "test hardware" I get the "Hardware error , check power and connection"
I am running a dell Lattitude E5440 win10 64 bit .
I am attaching a picture , all the LED's are lit.
any help is greatly appreciated.
912582 bytes
Charleebob Posted - 06/12/2020 : 20:27:49
Originally posted by fc227a
Oh, I am picking up the parallel port through the docking station
Last year a similar issue happened in my laptop chipset, I took many measures but the problem was not resolved, then I talked to dell support and got the product replaced. My laptop was in the warranty period, if your product is in the warranty period then you dell Try talking to customer support.
anniel Posted - 03/16/2020 : 05:45:09
Oh, I am picking up the parallel port though the docking station
Should work unless there is some kind of special drivers required for the docking station.
anniel Posted - 03/16/2020 : 05:43:22
greetings all,
912582 bytes
Was it working fine previously?
fc227a Posted - 03/15/2020 : 06:41:00
