 FUSE settings for pic18F2450
aERonAUtical96 Posted - 12/01/2008 : 22:31:29
Having problems w/ the PRG-017 programming the FUSE config bits on the PIC18F2450 chip. I attempt to program a HEX file w/ appropriate FUSE values. The hex appears to be set, but the FUSE settings will not. What setting am I missing?
ZLM Posted - 12/03/2008 : 11:58:45
Does the software load the configuration bit correctly from the hex file?
Try to increase the delay time in ".cid" file.
aERonAUtical96 Posted - 12/02/2008 : 07:11:09
Why will the software not erase the FUSE configuration? It won't set the config bit values from the HEX file
