T O P I C R E V I E W
mikec531
Posted - 02/12/2009 : 10:08:50 The only thing that the USB Pic Programmer does in the ICSP mode is says: The programmer does not recognise the [18f4321] processor Continue anyway?
It programs fine in the socket.
Any help would be appriciated.
Mike
Posted - 02/12/2009 : 21:32:06 Check your connection again, if no problem, then connect the ISCP from the socket using non-ICSP mode. See if it works in that way. This is to eliminate problem on your target circuit.
