 cant erase/write
Julez Posted - 08/21/2009 : 17:04:27
Hi i am new to this, and having a few issues.
Info XP,
PCB50
Version 50A
Software 0.98D9
adaptor psop44
Trying to work on Am29F200AB so44
I can read this chip but cannot erase / write to it.
i understand that more information will be required, but do not know what, so can someone kindly tell me what info is required and i will post up info
Thanks julez
Julez Posted - 08/22/2009 : 04:49:44
Thanks for reply.
have tried with and without, unprotect box checked, still the same.
i am unable to retrive ID, so will keep checking connections and report back.
Thanks for reply.
UPDATE
It would seem that it was just a chip / adaptor connection issue.
Once that was correct chip ID was found and all other functions were also accesable.
Many Thanks To ZLM for his help
Regards Julez.
ZLM Posted - 08/22/2009 : 02:20:15
First you should be able to get the ID. This will confim you have a good basic connection.
If the chip been locked, then the chip can not be erased or programmed, only read is allowed.
Turn on the Temporary Unprotect when erase.
