 Flashpro 400+
tahir Posted - 01/18/2012 : 14:22:08
Hello zlm i followed your device checked pin contacts I dnt get the mismatch error but it still won't program I load the file then it beeps bad adress error how do set it properly in the operation settings it's says to enter adress and config tabs could you plz explain to me where I'm going wrong thanks chip is mx29lv160cbt and trying to write 2mb to it but it's not having it thanks
ZLM Posted - 01/20/2012 : 22:33:54
if your adapter is correct one, then you need to check the programmer. I do not have this programmer, so I only can guess.
