 Fujitsu 29F400BC
benaknoun Posted - 07/22/2012 : 10:22:41
Hi
Does GQ-4X support this chip Fujitsu 29F400BC ?
I have bought a sop44 adapter, when i select this device on programmer, it says: Set the adapter to 5V jumper position
What does this mean? can someone explain what i should do because i don't want to mess things up..
luismtlopes@gmail.com Posted - 08/21/2014 : 14:20:44
It is OK to display MBM29F400B instead of MBM29F400BC. The MBM29F400BC is a sub-version of MBM29F400B.
If you really want to see MBM29F400BC, then add a new chip called MBM29F400BC
..The problem is not see the chip name, but even after cleaning the chip very well and try to read it several times, it always gives me wrong checksum
ZLM Posted - 07/29/2014 : 15:23:31
luismtlopes@gmail.com Posted - 07/28/2014 : 17:04:38
Hi!
trying to read 29F400BC fujitsu
ID 04AB fujitso MBM29F400B.
shouldn t detect like MBM29F400BC??
benaknoun Posted - 07/24/2012 : 15:05:13
OK
ZLM Posted - 07/22/2012 : 16:11:32
Your adapter is PSOP44 to DIP44. GQ-4X needs ADP-019 PSOP44 to DIP32.
benaknoun Posted - 07/22/2012 : 10:35:26
Hi
I have bought this adapter:
h**p://www.ebay.co.uk/itm/260960208767?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_nkw%3D260960208767%26_rdc%3D1
ZLM Posted - 07/22/2012 : 10:25:23
GQ-4X supports 29F400 PSOP44 package with ADP-019.
Set the adapter to 5V jumper position means set the adapter jumper to 5V position. There is a jumper on adapter for 3V or 5V. Set this jumper on the 5V position.
