 GQ-4x will not burn 29f033c
smarugg Posted - 05/30/2014 : 11:51:23
Any help with this would be highly appreciated. My GQ-4x will not verify, blank check, erase or burn 29f033c chips. I am using the TSOP adapter adp-077 along with the nesessary base adapter. The base adapter is set to 5 volts. I have also changed the device file as necessary to add the device for 29f033c. The changes I added we're this (taken from this forum)
Name="MBM29F033C*TSOP40",ID="04D4",Class="29F040B",Category="FLASH",MFG="FUJITSU",CodeSize="4194304",DIP="100011110101",Adapter="TSOP40B-DIP32(ADP-077 and ADP-082)";
The chips are from a reputable dealer that I have worked with in the past and I know they are OEM.
Does the GQ-4X not work properly with Windows 8? I used to burn 29f032b chips all the time but now those are not working either? I tested the burner with some 27c020 eproms and those are working fine with it.
Again, any help would be appreciated.
ZLM Posted - 06/02/2014 : 06:57:51
GQ-4X works with Win 8/8.1.
You should be able to read the chip.
