 buffer wont verify
vollosso Posted - 04/22/2015 : 14:36:07
Im pulling data from a TMS28F200AZ with the following hardware:
GQ-3x, ADP-019 v2.1 psop adapter, windows 8.1.
Im using 5v header and the right side of the 29f/28f header.
Every time i pull the data and try and verify it i get an error and every time the location is different.
Verifying... Code
Verify Failed, Address=0x000E04, Device=0x0A, Buffer=0x7C
Verify Failed
Elapsed time: 2.52 seconds.
ID check OK
Reading... Code
Elapsed time: 1.63 seconds.
Read completed.
ID check OK
Verifying... Code
Verify Failed, Address=0x001416, Device=0x80, Buffer=0xF8
Verify Failed
Elapsed time: 2.70 seconds
I cant figure out why it keeps doing this?
ZLM Posted - 04/25/2015 : 21:39:19
It looks to me is pin contacting issue. Check and confirm all pin contacting.
