 I can not read 35P08
Pablo Labrune Posted - 04/24/2015 : 07:34:26
hello I need to read this report but do not make it have a GQ-4X v6.3. I appreciate your help
ZLM Posted - 05/04/2015 : 19:24:20
You do not need the external power source for those chips.
Try to read those chips with USB connection only.
Make sure your adapter OR connection have no problem.
Pablo Labrune Posted - 05/02/2015 : 15:52:21
ZLM Hello, I have a question, note that when I test voltage, the controller stops responding. I tested connecting an external source and properly run the test voltage.
Could this be the problem you can not read the memory?
Pablo Labrune Posted - 05/01/2015 : 08:09:24
ZLM Hello my problem is that I want to read the memory and shows FF. The memory works because I put in the ecu and works well. I read it to modify the data to off immobilizer.
Yesterday I wanted to read a memory 95040 and also. Reading gives FF
You uninstall the program and returned to install it but without results.
I have two Gq-X4 and do the same so dismiss the programmer
ZLM Posted - 04/24/2015 : 17:54:05
What is your error message?
