 GQ-4X and PIC12F629 - CFG verify fails
Ziggy587 Posted - 08/14/2016 : 07:06:29
Hello,
I am trying to write to PIC12F629. I have three brand new chips. They ID check OK and blank check OK, but they all fail to verify the configuration.
Software/hardware/driver version and error message:
h**p://i59.photobucket.com/albums/g295/Ziggy587/CFG%20Verify%20Failed_zpskcbwy0zl.jpg
Configuration tab (Hex File):
h**p://i59.photobucket.com/albums/g295/Ziggy587/Hex_zpslpupsx7k.jpg
Configuration tab (Read from device):
h**p://i59.photobucket.com/albums/g295/Ziggy587/Read%20from%20Device_zpsw41dkjy6.jpg
(I would have uploaded the pics to the forum directly but was having trouble)
ZLM Posted - 08/16/2016 : 19:37:04
It seems the hex file configuration is not right. It is trying to change the reserved CFG bit.
From this chip datasheet, the Band Gap Calibration bits must be read and preserved.
So, do not use the CFG from your hex file.
