 d2764a verifies but doesn't work
jtmckinn Posted - 02/15/2017 : 06:07:54
I'm helping a friend revive some brunswick boards. I read the d2764a from a working board and verified them to the saved bin. pulled some d2764a's from a different board, erased, wrote, and verified those. Even though they verified when I try to boot the board with these burned chips it doesn't work. with the original rom set the board still works correctly. Any ideas?
anniel Posted - 11/21/2017 : 09:03:21
Originally posted by fusioncliffs
I had a recent issue with an Intel 2764A it would read only "FF" data and would not verify. After much trial and error I found out the Toshiba TMM2764A protocol works perfectly !
Thank you for the info fusioncliffs.
The only difference is WVCC="6.2V".
fusioncliffs Posted - 11/21/2017 : 08:41:40
ZLM Posted - 02/19/2017 : 00:18:56
Make sure the original chip checksum is same as the copied chip.
