 A25LQ16 A25LQ32A
rcolombo Posted - 10/04/2017 : 05:58:37
Hi, can't find device on Gq-4x For Flashing A25LQ16 y A25LQ32A, thanks
anniel Posted - 03/02/2020 : 08:11:40
Originally posted by Lookimback
Add following lines into devices.txt.
Name="A25LQ16*SOIC8",ID="C86015",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-081, ADP-081A";
Name="A25LQ32*SOIC8",ID="C86015",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081, ADP-081A";
You have the wrong device IDs.
I've corrected them and added the A25LQ64 as well.
Name="A25LQ16",ID="374015",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-081, ADP-081A";
Name="A25LQ32",ID="374016",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081, ADP-081A";
Name="A25LQ64",ID="374017",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081, ADP-081A";
Thank you for your contribution but the A25LQ64 has the wrong Codesize value.
Lookimback Posted - 03/02/2020 : 02:43:07
anniel Posted - 10/12/2017 : 10:24:09
at this point, there is no specific time line for this.
Ok, thank you.
ZLM Posted - 10/11/2017 : 09:40:57
anniel Posted - 10/08/2017 : 16:32:11
That is an hard question. The current GQ-4x4 hardware has capability to do the TTL/CMOS/RAM testing and identification, only need software to support it. However, due to the human resources short, this feature has been delayed.
Any time frame?
ZLM Posted - 10/08/2017 : 07:36:30
anniel Posted - 10/06/2017 : 02:58:07
Yes.
Try this version:
http://www.mcumall.com/download/TrueUSBWillem/USBPrgSetup7.14.exe
Install goes well and I see the devices.txt is bigger.
Any idea if or when TTL/CMOS/RAM testing and identification will be implemented?
Or will it be on the GQ-5X?
ZLM Posted - 10/05/2017 : 16:28:11
Yes.
Try this version:
anniel Posted - 10/05/2017 : 11:05:09
Hi ZLM, will there eventually be a new version of GQUSBprg reflecting all the new additions and modifications to devices.txt?
ZLM Posted - 10/05/2017 : 06:59:29
