 Routine Writings Failing Suddenly
John32 Posted - 10/21/2018 : 14:57:26
I'm trying to write a file on a M27C512. I have literally done this process thousands of times with no error. Suddenly I'm now getting this error on every chip I use:
Write failed, Address=0x000000, Buffer=0x00 Device=0xFF
The blank check function works fine and all chips are blank. What's going on?
anniel Posted - 10/23/2018 : 03:38:45
Originally posted by John32
The Hardware is detected and the voltage test said everything passed. I'll be honest, I don't really know what I'm doing with the hardware test. Is there something specific I should be doing?
Look for discrepancies between your readings and the I/O diagnostics page.
John32 Posted - 10/22/2018 : 19:22:38
anniel Posted - 10/22/2018 : 03:06:54
I've tried different batches and different chips. All are having the exact same error. I'm wondering if my GQ 4X4 is broke?
Try the hardware tests.
John32 Posted - 10/21/2018 : 18:49:03
anniel Posted - 10/21/2018 : 16:32:44
Same batch of chips?
Only M27C512 failing?
