 Help with GQ-4x4
scrappysphinx
Posted - 08/25/2020 :  04:29:32  Show Profile  Reply with Quote
Hi all, i have had my GQ-4x4 for a few years now and use it for programming retro console bios chips and amiga kickstarts.
Today i plugged it in to burn a 27c128 eprom for a sega master system bios but windows tells me it malfunctioned when inserting it into a usb2 socket. Inserting it into usb3 it appears fine and the gq software detects it and shows me the serial number. I then use the device button to select the 27c128 chip and the software starts to update the configuration but during this the programmer just starts beeping multiple times like it does when it first powers up. Despite this the software says configuration ok!
i then select the file i want to burn and click write only for the vcc light to come on but the program is frozen at 0.72%
I have tried multiple usb cables and multiple 27c128 chips but they all do the same thing
Anyone have anything i can try to get it working?
Posted - 08/25/2020 :  10:44:54  Show Profile  Reply with Quote
Did you change the USB cable? To communicate reliably with a programmer, a good quality USB 2.0 cable is needed.
scrappysphinx
Posted - 08/25/2020 :  11:53:25  Show Profile  Reply with Quote
As above i have tried different usb cables, 4 of them.
I have since opened it up and reflowed the solder connections on the usb port and zif socket. It then took a few tries but did eventually program the 27c128 and a 27c512 via the usb3 port. It still says its malfunctioned when plugged into a usb2 socket however.
Generated in 0.34 sec. Snitz Forums 2000
