 USB Driver install on Windows 10 does nothing
ynndecote
Posted - 09/13/2020 :  00:00:25  Show Profile  Reply with Quote
I have a Windows 10 64-bit VM running in VirtualBox on a Mac.
I run GQUSBdriver3.0Win10.64bit.EXE and it indicates a successful install.
I go to Device Manager and there is nothing added under "Universal Serial Bus controllers", and also there is no "Unknown device" under "Other devices".
Not a good first impression.
Posted - 09/13/2020 :  09:27:28  Show Profile  Reply with Quote
There are some setting may need to be set from the VirtualBox. That particular USB port/device has to be added to VirtualBox takes over the control.
But the VirtualBox is not tested.
ynndecote
Posted - 09/13/2020 :  10:10:37  Show Profile  Reply with Quote
Thank you for replying, ZLM. What about Apple's Boot Camp, should I try that instead?
ynndecote
Posted - 09/18/2020 :  22:45:39  Show Profile  Reply with Quote
For the record, I did get this working, after some struggle.
First I installed the VirtualBox Extension Pack. Then in VirtualBox Settings -> Ports -> USB
I deleted the existing USB Device Filter and added a new one with USB 3.0 selected.
Then in the VM I went through a few rounds of removing the device and driver from
Device Manager and then reinstalling. Also had to select the device a few times from
the popup list that appears when you click on the USB icon at the bottom of the VM
window. Eventually it started working. Have read a few EPROMs, haven't tried writing yet.
Posted - 09/29/2020 :  19:18:07  Show Profile  Reply with Quote
Great, Thank you for your update.
