 Slab Cutting Machine Correct Operation Method
Author  Topic Next Topic
owen
China
Posted - 08/19/2026 :  00:50:00  Show Profile  Reply with Quote
How to quickly repair a Slab cutting machine?
1. Any malfunctions encountered during the use of the Slab cutting machine should be immediately reported to the manufacturer for repair. Only professional technicians can diagnose and quickly resolve various malfunctions, restoring normal work output.
2. During machine use, avoid moisture and leaks to protect the machine's internal components and maintain their cleanliness.
3. During daily use, the Slab cutting machine should be inspected in advance. Any malfunctions should be repaired immediately to ensure the waterjet cutting machine can operate at high temperatures.
4. If the Slab cutting machine becomes noisy, check for oil or water leaks in the oil lines. High-pressure cleaning of the oil pump can help prevent blockages and malfunctions.
5. The Slab cutting machine manufacturer recommends regularly adding lubricating oil to the nuts of the feeder to effectively prevent malfunctions and improve work efficiency.
Correct Operating Procedures for a Slab Cutting Machine:
1. Simply turn on the slab cutting machine normally and let it start naturally for a few minutes.
2. Place the slab on the cutting platform.
3. The slab will cut into pieces during the cutting process. Observe the cutting process, paying attention to the cutting sound and the finished product.
4. Do not move the machine while it is in use.
5. Operators must be professionally trained and proficient in operating the machine. Non-professionals should not operate it.
6. The slab cutting machine is a high-precision piece of equipment, so its operation requires adherence to the "three fixed" principles (fixed person, fixed machine, fixed position).
7. Before operation, ensure there is no external interference and that everything is normal. Then, suspend the slab to be cut on the cutting platform, ensuring the slab does not exceed the cutting area.
   Topic Next Topic
