 93c56 I can read the chip, but can't write...
chevyp2p Posted - 08/13/2010 : 15:56:36
Hey guys,
I'm trying to calibrate an 02 honda Odyssey
ON chip 93c56. I can read the chip and when I try to write back to the chip the buffer shows that it's writing, however when I re-read it again nothing has changed on the chip.
any idea....
I've tried with the chip soldered to the printed board and also directly to the programmer.
using GQ-X4
Thank You...
anniel Posted - 09/15/2017 : 04:07:45
Originally posted by claudio
I'm having the same problem, erased, blank check and still nothing someone suggested to lower voltage to 2.75v, but it does not give me an option for voltage, any other suggestions?
Did you succeed?
Also curious.
We'll never know.
supervizeur Posted - 08/03/2017 : 05:51:14
Did you succeed?
Also curious.
anniel Posted - 07/15/2017 : 19:31:19
Did you succeed?
ZLM Posted - 02/05/2017 : 11:46:12
93c56 has two modes 8bit and 16 bit. If you do not know the mode, try both of them.
and make sure your chip is a good chip.
claudio Posted - 12/07/2016 : 10:36:31
ZLM Posted - 08/16/2010 : 06:42:40
Are you able to erase the chip?
After erase, do blank check to make sure the chip is blank.
The chip is confirmed chip on GQ-4X. So, make sure all pin contacting are good.
See:
chevyp2p Posted - 08/13/2010 : 21:13:37
I removed the chip from the printed board to make sure I had a good communication I read the chip directly to the programmer and I'm able to read the chip but not to write back to it.
Has anyone had a situation like this or know how to deal with this.
Any help will be very appreciated.
Thank You
ZLM Posted - 08/13/2010 : 18:38:10
IF the programmer software write and verified chip, then it should be write correctly.
Different board may have different in circuit programming. Not sure how your target hardware designed.
