 top853
honken Posted - 12/06/2007 : 13:11:14
I have a problems with my top853(have uv eraser)all brand new.
I can read 2732 and 27512 but i cant burn them.
With the new software it sas ex:20000:error! (file=ad,chip=ff)
Wath am i doing wrong.
And v2.52 dont showe checksum like v1.43.
honken Posted - 02/16/2008 : 03:54:14
Originally posted by ixlman
What was the fix? Others are having the same problem.
Not been here for a time but i hade no 12 volt on vpp and a transitor was burned.
ixlman Posted - 12/31/2007 : 08:43:37
honken Posted - 12/21/2007 : 03:18:58
Its fix nowe with help from support mcumall.
honken Posted - 12/11/2007 : 09:54:01
Check the Vpp pin during the programming, to see if the 12V Vpp is correct.
Found ic pinouts for the 27512 and tested the vpp for 12.5v
there is 0v when its programming.
ZLM Posted - 12/08/2007 : 18:10:23
Try any other chips for eliminating the programmer hardware issue.
The TOP software may have bugs on 27XX chips. You may need to try on the different software version.
honken Posted - 12/07/2007 : 09:44:15
I am newbe to this????
Did som testing today.
On the amd 27c512 it sas 4000 error file:f1 chip:ff ,i have erased it for 30 min.
On the ??? 2732 it sas oooo error file:49 chip ff ,erased it 30 min
Its the start adress for eproms but the eprom is blank if i check it on the top 853
Looks like it cant be erased or wath.
Its for my car,now i have driving with emulator to get it right but want a eprom.
thanks for the reply.
ZLM Posted - 12/07/2007 : 08:55:43
