 Topwin 2049 traduction fiasco!
ra2ven Posted - 04/16/2009 : 10:42:36
hello, i bought a top2049 recently and i see that there are some words whitout traduction in the software.
I need specially this:
In config (for pic16f84a), above "Config (bit)" there is a tab
whit four options whitout traduction.
Otherwise, if anybody can explain me the mean of the words below "Config (bit)", i would appreciate too.
Please, help.
tinhead Posted - 04/19/2009 : 07:19:50
it is always here - h**p://www.top2048.com/gb/tops/topwin5.exe
you can see in change log the date and version : h**p://www.top2048.com/gb/SoftRecord.txt
Version 5.69 E 2009-4-17
LATTICE GAL22V10B/D
thats the latest one...
ra2ven Posted - 04/19/2009 : 02:42:53
Its translation, my english......
I couldnt find the latest software, if someone could put a link i would appreciate
Thank you all
tinhead Posted - 04/16/2009 : 12:32:10
traduction ? i assume you mean translation.
Probably you have to download latest software version - i have v5.68 - no issues, there is everything in english.
oozelot Posted - 04/16/2009 : 11:50:17
you can find the minning of config bit into pic16f84a datasheet
CP CP CP CP CP CP DP CP CP CP PWRTE WDTE FOSC1 FOSC0
bit13 bit0
R = Readable bit
P = Programmable bit
- n = Value at POR reset
u = unchanged
bit 13:8 CP: Program Memory Code Protection bit
1 = Code protection off
0 = Program memory is code protected
bit 7 DP: Data Memory Code Protection bit
0 = Data memory is code protected
bit 6:4 CP: Program Memory Code Protection bit
: Power-up Timer Enable bit
bit 3 PWRTE
1 = Power-up timer is disabled
0 = Power-up timer is enabled
bit 2 WDTE: Watchdog Timer Enable bit
1 = WDT enabled
0 = WDT disabled
bit 1:0 FOSC1:FOSC0: Oscillator Selection bits
11 =RC oscillator
10 =HS oscillator
01 =XT oscillator
00 =LP oscillator
