 Top2049 verify problem
Henry Posted - 09/17/2009 : 15:12:18
hi there, i just have a top, and when i reprogram a eeprom 29f010 at the end of reprogrmation give me a error of verify, anyone apened the same?whow o can resolve the problem ?:( iám so disapoited with the top2049, if anyone can helpme i wiil be apreciate,
Thanks too all, and concratulations to this forum...
29   L A T E S T    R E P L I E S    (Newest First)
ixlman Posted - 11/30/2009 : 13:40:25
I know this is an old thread. I do not know about the 29F020, but I do know that the 28F020 will not work properly with version 6 Top software. I had to go back to version 5. I do not know why as they both use the same data files.
Henry Posted - 10/06/2009 : 15:19:47
thanks my friend :) but it is chinese for me :) hehe
osvaldo Posted - 10/06/2009 : 13:48:20
1 first need to know where memory is inserted
2 what you need is an editor and a file comparator Bin
3 what you want to make a memory emulator simulates this is for eeprom
Henry Posted - 10/06/2009 : 12:38:30
osvaldo, how i can make a IC tester in my top?...
iám going to the defination IC test, and give me the signal BAD
:( can be ths the problem?or how i can make this test alright?
thanks
Henry Posted - 10/06/2009 : 06:15:49
I just experiment, dont work my friend :(, i just put the eeproms in te ca and dnt start :) hehe...i dont tuch anymore on the top, i just gonna buy another reprogramer...
But if you know something, tell me ...
motocarlos Posted - 10/05/2009 : 14:49:27
Originally posted by Henry
hi motocarlos, maybe dont work with ssst 29ee010, try sst 29sf010 i am xure that will reprogram and verify well, i only dont know if that results in a car...
ok henry,
i will check it out, and tell you.
thanks,
regards.
Henry Posted - 10/05/2009 : 07:57:13
osvaldo Posted - 10/05/2009 : 04:31:46
Try recording as having sst29ee010 function q
device
EEP SST SST29EE010 ,SST29EE 4
33.45 KB
motocarlos Posted - 10/04/2009 : 14:56:00
hello,
i goes to the site top2048.com and i have downloaded the latest version of top software (6.08)
but with the eproms am29f010b-90 the software says error of verify, what can we do to that??
maybee is the programmer whos need to be update??
can anyone tell us if tha is possible??
best regards.
osvaldo Posted - 10/01/2009 : 19:06:40
watch this link this is what q me paso ami
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=1966&SearchTerms=osvaldo
osvaldo Posted - 10/01/2009 : 06:04:01
comfirmame if you get that bounce mail me or pass me Hotra mail
osvaldo Posted - 10/01/2009 : 05:47:26
Hello Henry I send you the latest version of the TOP program has both groin and Chinese language send the mail to you look it has to operate last changed chip brand as. SST
Oi Henry I lhe enviar a versão mais recente do programa TOP tem tanto virilha e idioma chinês enviar o e-mail para você olhar ele tem que operar marca chip modificado como. SST
Henry Posted - 10/01/2009 : 01:24:01
rrzrzrz the softwere dont works in my computer, this soft you pass dont have loadusb, and i open de program an says to me that is no device...
Abraço...
osvaldo Posted - 09/30/2009 : 04:37:26
My friend claims that all works well with any query that I am at your disposal needs for you and all the people and friends of the forum from now thanks
Henry Posted - 09/29/2009 : 01:10:50
osvaldo, yu ha recebido le email, obrigado :)
Depois de experimentar e confirmo se ha resultado :)
Obrigado amigo!!!
osvaldo Posted - 09/28/2009 : 19:28:35
HOLA YA TE LOEMBIE TO MAIL IF YOU CAME COMFIRMAME
osvaldo Posted - 09/28/2009 : 09:31:08
Tonight, TE VER 1.39 EMBI THE SOFT TOP program
Henry Posted - 09/27/2009 : 03:19:22
ok :), thanks, i will try :), my email is henriquehick08@hotmail.com,please send me the soft :)
osvaldo Posted - 09/26/2009 : 07:35:55
Download Attachment: Doc1.doc
81.31 KB
osvaldo Posted - 09/26/2009 : 07:32:01
It has to work with ssl29LE010 v and the soft top view you use is 1.39 and worked ok
Download Attachment: Doc2.doc
86.43 KB
osvaldo Posted - 09/26/2009 : 05:37:03
Hello you want the soft mandame un mail and I'll see 1.39 shipping
Henry Posted - 09/26/2009 : 05:08:00
Can you pass to me this software?
motocarlos do you experiment in this mode?works_?
thanks....
motocarlos Posted - 09/23/2009 : 13:45:46
ok,
thanks and i will wait too for some answer.
regards.
Originally posted by osvaldo
Hello Henry and proba motorcar with you: if you program tms29f010 Haver.
Today I will get a chip that you have and I do the same tests to see if I can help you to merge those problems so
Henry Posted - 09/23/2009 : 07:08:49
ok thanks and i will aguard a information...
bluurrr
osvaldo Posted - 09/23/2009 : 04:14:34
motocarlos Posted - 09/22/2009 : 16:25:39
Hello,
I have the same prblem with my top 2049.
Can anyone help us, please??
Best regards.
hi there, thanks for the responding, the eprom that i use is 29f010b,
today i will experiment the top with the definations that you say to muse,then i will tell you if it works or not :)
Thanks for all
With the best regards
Henrique Pitães
Henry Posted - 09/22/2009 : 11:39:00
Same problem, not work :(
Verify error :(
Henry Posted - 09/21/2009 : 07:53:39
Thanks for all
Henrique Pitães
simeon Posted - 09/19/2009 : 14:56:15
find the chip type in the device2049.lst file
you use eeprom but what maker???
also this string needs to be like this
EEP AMD AM29F010 ,AMD29f040 3 ,upr=0,vcc=5000,dly=2
ie add ,dly=2 to your devices string
and disconnect ALL other usb devices you can
make sure in your bios that the usb ports are set to use
480Mb speed
