T O P I C R E V I E W |
azure |
Posted - 03/19/2010 : 13:26:34 Hi I am having problems trying to write to my pic18F2525 chip. I have connected my chip via ICSP to the appropriate pins on the chip.
I select the pic with in the programmer and load the Hex file I'm trying to write.
When I try to write to the chip I get the error Error Program Memory at 0x000000
Any help would be Appreciated Cheers
5 L A T E S T R E P L I E S (Newest First) |
ZLM |
Posted - 03/26/2010 : 10:55:29 Try IC-Prog Software. that works with this programmer. |
azure |
Posted - 03/25/2010 : 03:36:50 quote: Originally posted by ZLM
That maybe software bug.
Ok, I am running the latest software that came with the programmer and I can find no newer versions online. Is there any other software compatible with the Willem pcb50 programmer? or do I need to go buy a new programmer..
ZLM |
Posted - 03/24/2010 : 20:46:16 That maybe software bug. |
azure |
Posted - 03/20/2010 : 10:26:13 Still no luck. First I clear the chip Status: "CHK Blank Code OK (no Checksum CFG)"
Next I select program the chip the software says "Programming Code (0x6000) Word" This reaches 100% It then says "Programming EEPROM (0x400) byte" This reaches about 60% and fails with a status of "Error Program memory at 0x000000"
chip need to be erased before write. Do blank check before write.
ZLM |
Posted - 03/19/2010 : 16:52:46 chip need to be erased before write. Do blank check before write. |
