 What is GQ-5X?
ZLM Posted - 07/09/2014 : 19:17:24
It is a new generation programmer: GQ-5X
The GQ-5X is a new generation of GQ series programmers.
The GQ-5X uses USB 2.0 as communication interface. So, it is much faster than previous models.
GQ-5X is not a single programmer, actually it is a series programmers. It includes GQ-5X NAND programmer, GQ-5X SPI programmer, GQ-5X universal programmer(48 pin) and more. The GQ-5X case is designed to be easily opened by bare hand, by changing the top module, the GQ-5X can be transformed to a professional level specific programmer. The objective is: try to achieve professional performance with affordable pricing, also provide flexibility to customers based on their application.
For example, if I want to program NAND flash at this moment, I only need to purchase PRG-120, so I do not need to purchase a $1000+ programmer which program many thing I do not need. Later on if I want to program high speed SPI, I only need to purchase a SPI top module.
The GQ-5X is much flexible than others. It uses newer concept to design. Each GQ-5X consist of two modules/parts. By change one of modules, it can be easily converted to a different application specific professional level programmer. Such as Hi-Speed NAND programer, Hi-Speed SPI programmer, General Universal programmer, Standard Xilinx JTAG Download Cable and more.....
The GQ-5X software GQ-Blaster is designed to support Windows, Linux and Mac OS.
55   L A T E S T    R E P L I E S    (Newest First)
entertex Posted - 07/06/2016 : 03:41:45
DS2431 (DS24xx Dallas) 6tocs, ?????
sammual777b Posted - 09/28/2015 : 10:13:29
These are probably bad bits from the output nand device. ECC will correct some of them otherwise they will be marked as a bad block.
Problems with the programmer/software would result in consecutive errors.
M.
Originally posted by eduardo48
Hi, I upgraded to version 1.01, error verification, to verify consecutive error in different directions.
C:/Users/Eduardo/Desktop/NAND/unxx5500-version gq-5x 1.01.bin Loaded
-verify
Compare data Failed address 1F704A6E ,target FD,PC memory FF
-verify
Compare data Failed address 1F71B046 ,target E1,PC memory E9
-verify
Compare data Failed address 1F7939CE ,target 35,PC memory 3D
-verify
eduardo48 Posted - 09/04/2015 : 17:32:57
-verify
-verify
-verify
-verify
GQ5XSupport Posted - 09/03/2015 : 21:12:49
Download 1.01 now. It fixed the issue for larger that 4GB chip.
GQ5XSupport Posted - 09/02/2015 : 21:29:56
Checked, received new memories K9GAG08UOE recorded with original firmware, can not be cloned, erroneous verification.
This programmer does not work with 16gb memory
Working on a fix now. Will release a fix soon.
eduardo48 Posted - 08/29/2015 : 16:11:41
airdorn Posted - 08/20/2015 : 04:45:04
Please support 87C51RD2-MCB
eduardo48 Posted - 07/24/2015 : 15:32:40
Hello, Lookinback, the process did so, read, and then verify, compare the reading with the chip, to verify the consecutively error in different directions.
The chip it extracted a tv running perfect, I copy the firmware for backup
I am glad you have good results
Lookimback Posted - 07/23/2015 : 12:51:16
When you get the compare data failed message, it is because the binary file doesn't match the binary data on the IC. If you scroll down to the target address, you will see that it is different from that point. Extracted memory from a working TV could possibly be a different firmware version. I'd say you either have a different firmware version, or the data on one IC is corrupted. Back up the binary from the IC, then flash the binary from the working TV, then use verify to compare. My 5X came a couple days ago and it's been great.
eduardo48 Posted - 07/19/2015 : 17:04:07
Estimate because this occurs, consecutive to verify the error is in different directions, I clarify that a memory of a tv extracted in operation.
I only read and verified with this definition,Name="TC58NVG1S3HTA00",MFG="Toshba",ID1="98h",ID2="dah",ID3="90h",ID4="15h",ID5="76h",size="11000000h",PageSize="880h",BlockSize="40h",Speed="5"
Copyright (C) 2014-2018
GQBlaster 1.00
Target: TC58NVG1S3HTA00
C:/Users/Eduardo/Desktop/NAND/NOBLEX-32LD867HT-11000000.bin Loaded
-verify
Compare data Failed address A245035 ,target 3E,PC memory 7E
-verify
Compare data Failed address A4DD8B4 ,target CD,PC memory CF
-verify
Compare data Failed address A3BFDBD ,target 1A,PC memory 5A
GQ5XSupport Posted - 07/16/2015 : 12:21:00
Hello, the definition created. Name="K9GAG08U0E",MFG="Samsung",ID1="ech",ID2="d5h",ID3="84h",ID4="72h",ID5="50h",size="88A7d800h",PageSize="21b4h",BlockSize="80h".
I tried ID6 value 42h with the same result.
You can test a k9gag08uoe scb0 memory.
to verify, this occurs, you can give me an explanation on possible failure.
-detect
K9GAG08U0E
C:/Users/Eduardo/Desktop/NAND/UN32D5500RG-K9GAG08UOE-COMPRADA.bin Loaded
-program
Program Starts...
Program time 00:06:31 (.172)
-verify
Compare data Failed address 2214DC ,target FB,PC memory FF
I have not tested this chip myself. However you should first program all ffs and see if you can get the chip erased. If not your chip should have bad blocks.
eduardo48 Posted - 07/14/2015 : 16:22:31
-detect
K9GAG08U0E
-program
Program Starts...
-verify
GQ5XSupport Posted - 07/13/2015 : 09:16:55
Hi ZLM, are not added , I myself have created definitions nand k9gag08uoe, not work with this programmer.
What is your definition? How do you define is not working?
Can you read properly or erase properly?
This flash is quite small in size and should not have any issue.
eduardo48 Posted - 07/13/2015 : 08:30:45
ZLM Posted - 07/09/2015 : 11:17:50
K9GAG08UOE and 27U4G8F2DTR shoud in latest sotware relase.
eduardo48 Posted - 06/12/2015 : 19:14:21
Hello, I buy GQ-5X NAND. can you add definition file K9GAG08UOE and 27U4G8F2DTR
ZLM Posted - 04/30/2015 : 18:46:06
GQ-5X NAND is able to support supports K9GAG08UOE and 27U4G8F2DTR.
ZLM Posted - 04/30/2015 : 18:45:03
GQ-5X will not combine hi-speed SPI with hi-speed NAND. Those are two modules. There will be a GQ-5X Universal.
eduardo48 Posted - 04/29/2015 : 19:52:31
Hi, supports K9GAG08UOE and 27U4G8F2DTR
tibimakai Posted - 03/24/2015 : 21:02:40
Why the GQ-5X is limited only, for 25xxx EEPROMS?
It shouldn't be able, to do all that the GQ-4X can do and in addition can do the 25xxx?
Do you know when the GQ-5X universal will come out? What will it's capabilities will be? SPI and Nand combined?
ZLM Posted - 03/24/2015 : 16:58:32
TC58NVGxxxx is NAND flash. You need GQ-5X NAND.
The 24XX, 25XXX are the EERPOM. You may need to get GQ-4X for those EEPROM chips. The GQ-5X SPI only for 25XXX EPROMs.
Yes. If you have GQ-5X SPI, you can transform it into GQ-5X NAND. They have same base board. You just need to buy a NAND Flahs module.
tibimakai Posted - 03/22/2015 : 09:35:54
Anybody can help?
I'm trying to understand these two programmers how they can be used, it's a bit confusing.
Let's say, if I would buy the SPI version, can I transform it into a nand flash programmer, by replacing the adapter on top of it?
tibimakai Posted - 03/17/2015 : 21:03:53
I'm new in this field, I have never programmed anything yet and I'm considering this programmer because it supports a Toshiba TC58NVGxxxx nand flash, which I'm planning to program.
What I would like to find out, if this programmer can program all the regular EEPROMS as well, like the 24C, 25C series and the like?
When it will be available, by the way?
Thank you,
Tibor
johwaa Posted - 03/04/2015 : 20:00:07
Okay, Thanks!
ZLM Posted - 03/04/2015 : 17:19:13
2-3 weeks
johwaa Posted - 03/02/2015 : 14:01:24
The status on the GQ-5X shows that they are on backorder, when can we expect them to be in?
Thanks,
John
PFM Posted - 02/20/2015 : 11:52:21
Thanks!
GQ5XSupport Posted - 02/19/2015 : 21:14:17
Here is the latest NAND text.
Download Attachment: Nand.txt
5.37 KB
PFM Posted - 02/17/2015 : 04:28:27
Hello! Where can I download the new GQ-5X definition file, including also those Samsung NAND chips, please? Thanks in advance.
PFM Posted - 02/16/2015 : 17:19:59
Thanks! I bought it this morning and it is already on the way!
GQ5XSupport Posted - 02/16/2015 : 15:38:21
Originally posted by PFM
Hello, I wish to buy GQ.5X NAND.
I need to use it to recover firmwares when they go bad on a multimedia device.
Does GQ-5X NAND support these Samsung NAND device?
- K9F4G08U0E
- K9F2G08U0C
I need to perform full dumps from fully working devices, and then I need to overwrite devices when they come back to service due to corrupted firmware's issue to fully restore them.
Is it possible to do it using GQ-5X NAND, please?
Based on datasheet, there is no issue supporting these chips. I have added them in the definition file.
PFM Posted - 02/15/2015 : 15:43:43
- K9F4G08U0E
- K9F2G08U0C
ZLM Posted - 01/15/2015 : 16:23:42
sure. This is a small capacity chip. GQ-5X supports it with no problem.
electricmobile Posted - 12/19/2014 : 04:23:02
Hello.
does the GQ-5X support MT29F2G08ABAEA from Micron? Where is the full IC support list?
Thanks.
ZLM Posted - 12/01/2014 : 20:38:58
The GQ-5X Universal is not available yet.
Current available models are GQ-5X SPI and GQ-5X NAND.
hamidfx76 Posted - 11/29/2014 : 16:36:29
Hi there,
I want to useing GQ-5X to programing the bios pc, laptop and hard disk. Can you tell me please which one I must bay?
When is available the GQ-5X universal programmer?
Thanks,
Hamed
benaknoun Posted - 11/24/2014 : 15:16:10
ok
good to know
GQ5XSupport Posted - 11/19/2014 : 21:39:28
Originally posted by benaknoun
Hi
Does it support? :
Intel tsop56 TE28F640J3c120
Intel Flash 28F120J3D75 BGA64
This is Nor flash. So far 5X supports Nand and SPI flash. In the future Nor flash will be supported.
benaknoun Posted - 11/15/2014 : 14:20:19
Hi
Does it support? :
GQ5XSupport Posted - 10/16/2014 : 14:25:29
Make sure it is 8 bit wide. 16 bit is not supported yet.
But it will be supported in the future software update.
GQ5XSupport Posted - 10/16/2014 : 14:22:05
NAND512W should not be a problem. I see some issue with large flash. 8GBytes and beyond.
ventour Posted - 10/16/2014 : 03:00:32
the chip is NAND512W
GQ5XSupport Posted - 10/15/2014 : 10:44:54
Under tools you can select edit the device file to add your device in. Each line defines one device.
GQ5XSupport Posted - 10/15/2014 : 10:43:41
Please provide the detail about the chip.
We might need to update the configuration or possible new release for some chip that is not tested yet.
ventour Posted - 10/15/2014 : 01:55:35
Hi guys.
I just bought GQ-5X and i face some difficulties on programming some chips.
Is there a step by step guide to follow?
Thanks in advance
ZLM Posted - 09/07/2014 : 09:00:26
The current device list is focused on the devices not been covered by the GQ-4X.
See:
http://www.mcumall.com/devicelib/TList.asp
jzio Posted - 09/06/2014 : 02:12:38
What is the list of supported devices so far ?. Thank you
stylius Posted - 08/14/2014 : 08:21:55
Hi.I have gq-4x. I love it, low cost and good working. But now need more, need read 29XL12DF, S29GL128, K9F1G08U0B flash chip. So it will in new programmmer? when it will be release to public? I want buy it. Please tell more info about new programer. Thanks.
ZLM Posted - 07/29/2014 : 15:29:55
GQ-5x consist of a set of programmer sub-models: GQ-5X NAND, GQ-5X SPI, GQ-5X Universal, GQ-5X JTAG etc.
All sub-models shares base module, and it has specific top module. So, they have different price. Beside the universal model, all others should be device specific. And they are expected to have professional level performance.
PlusPlus Posted - 07/28/2014 : 13:27:10
Estimated price?
mpatou Posted - 07/22/2014 : 06:39:38
Should de write down devices we'd love to have supported by gq5x? :D
cemswan Posted - 07/18/2014 : 07:51:25
AM29F032x tsop40
ATMEGA8515L tsop44
S29GL256P90TFCR2 TSOP56
Jeff Posted - 07/15/2014 : 16:45:13
tms370c002
tms370c702
mchc05b6(OF10V)
mchc6811e9
mchc05b6 (3d33J)
mchc05b6(OB91T)
ZLM Posted - 07/15/2014 : 06:28:32
It will.
The new concept used on GQ-5X allows software to supports any chips by changing the top part. The top part can be easily changed in seconds.
Proposed supporting list:
TMS370CX6X
TMS370CX5X
TMS370CX4X
TMS370CX3X
TMS370CX0X
TMS375C006
TMS374C003A
TMS374C013A
MC68HC05V12
Please add your chips you needed here.
Jeff Posted - 07/14/2014 : 13:58:18
Will it do motorola mcus?
