T O P I C R E V I E W
don954
Posted - 10/18/2007 : 16:21:39 So i have the enhanced dual power programmer, the jumpers are all set in the original positions PCB3.5 and i'm using the correct software for that setting. I have set the parallel port to EPP in the bios. I have chosen the correct oscillator settings and turned code protect off etc. I have a program that was created in mikrobasic, and i know it works because i have tested it on PIC16F88's at the university using their programmers. When i try to program it on the 88's i have at home, it does not verify. I did notice that for most of the other PIC chips the picture tells you where to put your MC but when i select the 88 from the device menu it doesn't show any MC in the little picture.. possible problem? I have been putting in the location for a PIC16F676. Does anyone have any insight as to why it would not be verifying? I am very frustrated and would really appreciate any help.
Thank you.
2 L A T E S T R E P L I E S (Newest First)
Posted - 10/21/2007 : 18:36:30 Did you try using the software IC-prog1.05D?
don954
Posted - 10/21/2007 : 12:13:32 Anybody have input? do i need to provide more info or be more clear about the problem or perhaps my question?
