 Problem with USB-Pic programmer
kitt1977 Posted - 02/14/2009 : 14:15:45
When load a hex file to program a PIC18F2550 is get following problem.
78.71 KB
So i can't program the hex into the pic afther the error message the hex is not loaded ..
What could i do about it ?
Tom
ZLM Posted - 02/15/2009 : 16:24:17
The file fomat is incompatible on fuse section.
Use WinPIC800 read the file and then save as into second hex file. Use USB PIC Prog to open the second file.
Check all you fuse values are correct before write into the chip.
kitt1977 Posted - 02/15/2009 : 01:13:14
it's not corrupt , if i load it with Winpic or PicPGM is' load without problems , problem is those programs don't work with the usb programmer .. i have to use USB PIC PROG ....
h**p://www.on4top.be/pic/Node.03.37.hex
R
tom
ZLM Posted - 02/15/2009 : 00:16:10
can you sent me your hex file? your hex file may be corrupted.
