 I need to manufacture tsop48 interface
Hernan Posted - 02/28/2011 : 03:50:21
Hello, I have the willem usb, I need to manufacture tsop48 adapter, enclosed the images of my adapter
For read MX29F016
24.35 KB
186.53 KB
29.2 KB
ZLM Posted - 05/02/2011 : 21:19:59
I think the programmer got some problem.
Hernan Posted - 04/29/2011 : 04:16:43
Hello, for MX29F016, I choose AM29f016, he/she doesn't read, single bad load the information
178.96 KB
to record, he gives me errors, I am not able to record the flash
52.02 KB
pin in adapter V 1.0-V2.0 and I plug the adapter in pin TSOP40A and TSOP40B, but I am not able to read neither to record
20.04 KB
Some other idea or he/she helps
My English excuse I use translate
ZLM Posted - 04/24/2011 : 17:37:13
If your programmer is GQ-4X then you do not need any address line connection.
If your programmer is GQ-3X, then you need to connect A19, A20, A21
Hernan Posted - 04/23/2011 : 04:29:04
another question
I buy
1 ADP-077
2 ADP 082
question, do I connect in the jumper J4 of the ADP-082?? to the jumper J4 of the willem?
A19 ..adp-082 to A19 to pcb willem ?
A20 to A20 to pcb willem ?
A21 to A21 to pcb willem ?
Selec model MX29LV ??? only in those requests adapter
thank you for their patience
excuse my ignorance
ZLM Posted - 04/03/2011 : 07:07:33
Your ship should be TSOP40 package.
If you already got ADP-082, then you only need the ADP-077.
The ADP-033A should work too.
Hernan Posted - 04/02/2011 : 05:47:59
will I solve the problem with this I articulate??
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3102
or I need
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4426
I have this adapter
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4418
TNK
ZLM Posted - 03/04/2011 : 08:26:40
use ADP-082 with ADP-077
Hernan Posted - 03/03/2011 : 05:17:58
Thank you, very clear their explanation
Hernan Posted - 03/02/2011 : 03:51:31
this?
25.4 KB
34.91 KB
thank you in advance
