T O P I C R E V I E W |
steve |
Posted - 02/21/2007 : 15:46:10 hi, help me, I have a top2004 programmer and can't read D27011 eprom, the program topwin display: problem pin contact of: 6,35,36. But this pin no to exist! 27011 is 28 pin eprom, in 40 pin socket of programmer, 1-6 35-40 is not conected.
Best regards |
6 L A T E S T R E P L I E S (Newest First) |
steve |
Posted - 03/03/2007 : 05:59:51 help. Perhaps the tension for programming is'nt correct. (With write command the software stop in first addres and display this error "file=00 chip=ff"). I ask, is possible to forced the programming voltage whit external tension without damage the top programmer? The top2004 programmer factory have a consumer suport mailbox?
Best Regard
steve |
Posted - 03/01/2007 : 13:58:16 I have try with last software version. I can not write the 27011 eprom. I try with 27011 and 27513 set. In 27011 set, no read and no write In 27513 set, the writing stop in first address of memory
Best Regard
steve |
Posted - 02/28/2007 : 15:49:25 ok, i have topwin 2.32 version, now dounload 2.35 version and try.
bye (ciao)
Mauro |
Posted - 02/27/2007 : 08:11:50 These devices have a voltage different from writing that of reading, your problem can be the soft TOPWIN, that version you have? you can unload the last version of http://www.top2048.com/gb/soft.htm
Best Regard |
steve |
Posted - 02/22/2007 : 14:26:29 27513 type and 27011 eprom: with read command all ok, with program command, topwin display: error!(file=00 chip=ff) can you help to me
best regard |
Mauro |
Posted - 02/22/2007 : 08:17:24 try with 27513 or 27C513 eproms. bye |
