 12f683 yaosm problem
guerrierodipace Posted - 05/01/2008 : 02:33:04
I tried to program chip with this software for wii console modchip but,like with the willem 4.5c,have a problem for correct programming.
In willem lpt I can use software winpic800 but with usb willem this program don't work :(
Any solution?
ZLM Posted - 05/14/2008 : 07:32:39
The configuration bit value selection is based on the software/application. So, the chip will not work if your CFG value incorrect.
guerrierodipace Posted - 05/14/2008 : 04:28:26
It seems the CFG bit not been write correctly.
can I try some different configuration next time I receive a wii console to test?
ZLM Posted - 05/13/2008 : 16:36:05
guerrierodipace Posted - 05/13/2008 : 07:45:55
when I write this program with your software or the one in bundle with willem lpt don't work (no error in programming).
If I use winpic800 on lpt willem this pic works well.
I am not a programmer I don't know the reason but this happen
ZLM Posted - 05/12/2008 : 19:35:39
The 12F683 is supported.
see:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=1288
If it does not work, post your exact error message or problem you got.
guerrierodipace Posted - 05/12/2008 : 14:43:11
sorry but I buyed true usb for not use LTP !!!!
I don't need true usb if don't work for the task I need?
are you agree?
ZLM Posted - 05/02/2008 : 16:55:54
The True-USB Willem software only for USB Willem. It will not work on any LPT willem programmer.
Use IC-Prog software for all LPT type Willem programmer.
