 Need help in mikroC coding
enduo Posted - 09/27/2010 : 18:24:11
Hello there
I recently bought one of your programmer and was very satisfied with it
EXCEPT i know nothing about PIC and i am learning
I know how to code them in C and i am simulating all my circuits in ISIS (Proteus extension i think...)
I received a complementary chip with my programmer, and so far my codes in C only worked on that chip (12F629)
So i am having a problem coding a 16f877a
I am using mikroC ...
Do you recommend a better software BUT that doesn't use ASSEMBLY language because i found it so complex at first :D
If there is anything i should know please let me know
I can provide my codes if you want to
enduo Posted - 10/02/2010 : 09:57:55
checked the CFG, all is good
i think my problem is in the OSC circuit
can you show me a circuit of what i should build to use with my 8MHz crystal ?
the reason why it worked on 12f629 i think is because it uses its internal oscillator which is not found in 16f877a
and considering this is my first time around these things, i don't think im doing it right :(
ZLM Posted - 09/30/2010 : 22:13:30
if the chip can be verified, then the chip is porgrammed correctly.
check your CFG bit, see if it is set correctly.
enduo Posted - 09/30/2010 : 09:20:12
Thanks for the reply
Yes i can write in C and simulate them in ISIS
In the ISIS, when i simulate the hex file with the circuit it works
But when i do it in practical it doesn't
I am sure of all the connections and the programmer is working fine..
Is there a chance that the chip is burned or malfunctioning ?
And would the programmer i bought from you tell me if the chip is burned?
ZLM Posted - 09/28/2010 : 20:44:42
mikroC should be fine as long as you can write it and it can be compiled into .hex.
C language is a pretty good one if you can use it.
