 Cant write to 27C322 Eproms
topgeargames Posted - 11/25/2011 : 21:58:14
hey, i have tried to write to multiple eproms of the 27C322 type, all with no luck. I am using a 18V ac power supply, and have also tried it with a 12V supply.
The chip is recognised and blank check shows its empty, and then when i go to write to it it writes all the wrong bytes of code!
Every last byte is wrong. but it manages to write the entire chip.
What am i doing wrong?
Im using willem version .98D5 on PCB50.
ZLM Posted - 12/15/2011 : 11:29:46
This is the only adapter for this chip.
topgeargames Posted - 12/07/2011 : 15:35:05
Thanks for your help so far ZLM.
So you think the adapter is faulty? That sucks, i bought it from MCUmall and it hasnt worked since i got it, so i guess it makes sense that it could be faulty.
Is there a different adapter you would recommend?
ZLM Posted - 12/05/2011 : 22:24:12
The adapter is wrong in this case.
topgeargames Posted - 12/01/2011 : 09:51:29
No ZLM you miss read that. EVERY byte is wrong. i meant all of them. I even tried a different programmer (GQ-4X) and it fails at the same spot every time. Im using the ADP-054 adapter with the 4X and still nothing. Heres what happens:
"Chip is blank
c:\users\downloads\test.bin.
Speed = 3
ID check skipped
Writing... Code
Elapsed time: 2.44 seconds.
Write failed, Address=0x000000, Buffer=0x4C Device=0x48
Write failed"
It fails at the same place every time. I bought the GQ4x because i thought my willem was faulty, but now the 4X is failing too so i dont know what to do...
ZLM Posted - 11/30/2011 : 20:20:01
If it only the last byte wrong, then looks like software related. Try use other software version. Like 0.97j version.
topgeargames Posted - 11/30/2011 : 13:04:53
Come on people! this site doesnt have much for forum activity do they... I am in need of any answers here. I cant find out any information, ive done extensive searching on the web and cant seem to find anything out. Seeing as this site is for people who use eprom programmers i expected a better turn out
