 GQ4X: Read Works, Write Fails: AM27C010
laanguiano Posted - 06/25/2016 : 11:23:46
I read 2 other of the same EPROM type, and they read fine. This one read blank. So i figured this one needed to be re-written. Loaded a bin File, checked blank, made sure correct device was selected. and hit write (tried various speeds), and got an error.
Its plugged into back of PC, with power supply attached. Also i did the voltage diagnostic test and it came back fine.
Any clues/??
Here are pictures of the fail screens
https://drive.google.com/folderview?id=0B_BNDhLd8jmBanV2SmVERnM2ZGc&usp=sharing
ZLM Posted - 07/02/2016 : 13:54:20
What is the exact error message?
Brumby Posted - 07/02/2016 : 01:47:47
I have the same issue with 4x4 with 27sf010 27c010 Eproms.( Have tried 10 chips same result Fail instant on write. My previous 4x used to work fine
ZLM Posted - 06/25/2016 : 21:57:21
You should be able to red chip ID.
If ID is wrong, then you need to find out why.
You do not need the external power supply. The USB power is good enough.
anniel Posted - 06/25/2016 : 13:02:23
Bad contact or bad chip.
