 GQ-4X can't erase 28F400 -=SOLVED=-
ZRimas Posted - 09/03/2016 : 10:43:53
Hi!
Recently I got problem: original GQ-4X can read and verify 28f400 w/o problems, but when I try to erase the flash, it comes to 100% and the software hangs up with programmer's all 3 LEDs ON. Software update to the newest and computer change did not help.
Any ideas?
83954 bytes
ZRimas Posted - 10/02/2016 : 07:43:45
The problem was faulty ZIF socket :(
ZRimas Posted - 09/11/2016 : 23:10:35
No, they are not
ZLM Posted - 09/11/2016 : 13:47:53
Those chips are locked? In that case the check may not be able to erase.
ZRimas Posted - 09/11/2016 : 09:15:59
5 chips in the row?
ZLM Posted - 09/05/2016 : 21:01:18
The damaged chip may not be visible.
ZRimas Posted - 09/04/2016 : 11:16:47
My first ideee was also the same. Tried many, result was the same.
Adapter is the same as before. Checked it visually - no damage.
ZLM Posted - 09/03/2016 : 21:59:31
The chip may be a bad chip.
Try another chip if possible.
