 vsop adapter
jpeters Posted - 03/30/2017 : 11:47:36
What is everyone using for an adapter on these vsop chips? These are wider that a standard soic. About 5 mm. I have a chip clip with wires but would rather have the adapter. The software says use adp-081. I think I have that one but it`s too small.
anniel Posted - 04/01/2017 : 16:21:08
You are right.
supervizeur Posted - 04/01/2017 : 12:42:22
If its not labeled it's probably a Chines fake.
anniel Posted - 03/31/2017 : 11:45:44
A quick Google search brings 150mil for ots-16-03. Use this info AYOR.
jpeters Posted - 03/31/2017 : 10:26:43
The adapter I have is not labeled. I thought it was an adp-081. I will order another to be sure. The number on this adapter is ots-16-03. It may be for like a 24c08 soic.
anniel Posted - 03/31/2017 : 05:21:52
The Macronix MX25L3206EPI is a regular 300mil 8-PDIP and goes directly to the ZIF socket and the MX25L3206EM2 is a 200mil 8-SOP and ADP-081 is correct.
jpeters Posted - 03/31/2017 : 03:59:21
For example MX25L3206 Macronix
anniel Posted - 03/30/2017 : 12:17:16
Which chip are you referring to?
