T O P I C R E V I E W |
xefned |
Posted - 05/21/2017 : 04:23:52 Hi, I'm a novice to using the GQ-4X v4, although I've used a Genius G540 for several years.
I'm burning 3 M27C160's for a friend. The first one I burned without performing a blank check.
One the 2nd chip, I clicked 'blank check' first and it failed. I proceeded to write the chip and verify it.
Is it still OK if the chip verified correctly? I'm assuming the GQ-4X writes over any non-blank sectors. But it will likely be months before my friend installs these chips.
What do you think? Will they work? |
4 L A T E S T R E P L I E S (Newest First) |
supervizeur |
Posted - 05/30/2017 : 06:36:49 quote: Originally posted by anniel
Not necessarily, You can do a refresh as you do a double write.
True. |
anniel |
Posted - 05/29/2017 : 08:40:46 Not necessarily, You can do a refresh as you do a double write. |
supervizeur |
Posted - 05/29/2017 : 05:57:16 You nevertheless should erase the chips before burning them. |
anniel |
Posted - 05/21/2017 : 06:11:24 If the device is not blank and the verify is ok, its because the chip already contained the same data at least partially. You just re-burned the same bits like a double write. |
