 GQ4X - W25Q64FW support
khaahk Posted - 05/22/2015 : 02:37:34
Datasheet:
h**ps://www.winbond.com/resource-files/w25q64fw_revg_aug1414_sfdp_dms.pdf
The chip is 1.8V, what line should be added to devices.txt
supervizeur Posted - 06/04/2017 : 09:02:23
Originally posted by pashha
Dear, Can you write more details about the resistors? (Watt ? )
No real importance, any wattage you have on hand will do fine.
+1
anniel Posted - 06/01/2017 : 05:23:22
pashha Posted - 05/31/2017 : 08:16:31
I modified adapter drawing from original drawing of EZoFlash adapter.
43.6 KB
ZLM Posted - 09/08/2015 : 12:26:48
ADP-099 See:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4630
[b]Image Insert:[/b][br][br][size=1] 71.31 KB[/size=1]
long123 Posted - 08/06/2015 : 20:03:50
This chip needs a 1.8V SPI adapter. The programmer ZIF socket provides a 3.6V VCC minimum.
ZLM Posted - 07/24/2015 : 23:51:16
43.6 KB
laptech Posted - 07/23/2015 : 02:44:38
You can make a one yourself.
See EZOFlash 1.8V SPI adapter:
h**p://www.ezoflash.com/scriptdapters.htm
I was thinking of making this adapter because I have a couple of 1.8v chips to program but looking at the pictures I am confused as to how this connects to the GQ-4X. I can see where the 8 pin SPI adapter plugs in (2 rows of 4 connectors) but it appears there is also another 8 pin connector which I assume is supposed to connect to the programmer but the GQ-4X has not such connector so if I make this 1.8v adapter, how do I connect it to the GQ-4X?
many thanks
Rog
ZLM Posted - 05/22/2015 : 09:21:53
