 Mitsubishi M5M27C100P-15.
jacob_1988 Posted - 11/14/2017 : 07:29:37
I cannot seem to find the EPROM [Mitsubishi M5M27C100P] in the device list of the GQ-4X4? Would it be feasible for someone to explain to me how to add the correct information so I may write to the EPROM.
anniel Posted - 11/18/2017 : 08:49:32
Originally posted by jacob_1988
Thank-you, I will try later on tonight to see if the eproms burn correctly :)
Ok.
jacob_1988 Posted - 11/18/2017 : 08:17:37
anniel Posted - 11/18/2017 : 07:13:58
To be truthful... I haven't added any 'new' information to the device.txt because I couldn't find the correct info to add. The datasheet info (that I matched) was from h**p://www.datasheets360.com/part/detail/m5m27c100p-15/-7143483480754405839/?alternatePartManufacturerId=0
The info (as below) is taken from the original Device.txt in GQ-4X4.
Name="M5M27C100K",ID="XXXX",Class="27C301",Category="EPROM",MFG="Intel",RVpp="5V";
Ok, add those 2 lines and see if it's good for you.
Name="M5M27C100K",ID="1C02",Class="27C301",Category="EPROM",MFG="Mitsubishi",RVpp="5V";
Name="M5M27C100P",ID="1C02",Class="27C301",Category="EPROM",MFG="Mitsubishi",RVpp="5V",Message="OTP";
jacob_1988 Posted - 11/17/2017 : 12:52:14
anniel Posted - 11/17/2017 : 11:58:02
Can you paste the device line you added?
jacob_1988 Posted - 11/17/2017 : 10:21:06
There doesn't seem to be much difference but when I add the M5M27C100K (in the GQ-4X4) it says 'intel' instead of Mitsubishi?
Memory IC Type is different as well.
anniel Posted - 11/17/2017 : 07:02:47
Did you look what is the difference between the M5M27C100K and M5M27C100P in the datasheet?
