 AMD AM29F040B Problem
rrold2 Posted - 05/08/2008 : 08:50:21
I just received my new programmer. It was to replace my earlier one because I though that there was a problem with it (the one with the DIP switches). Apparently, the programer isn't the issue. I also got a new adapter.
I am trying to program an AM29F040B and it seems to program fine but the device it is then installed in wont run. I took a AM29F040B chip with an earlier firmware version on it (I did not program it) and the device ran fine. I then took the same chip and programmed it with a new version of the firmware. The device no longer runs with that chip. It chip erases, blank checks, writes and verifies. I even did a read on the newly programmed chip and it does appear to have been programmed. I have tried with a number of chips. I had a supply of the ST Microelectronics version and they were fine but I don't have any more of those to try.
Any ideas?
Additionally, I have some Hyundai HY29FO40AC chips but they are not in the library. How can I set up to program those.
I am new at this so please reply as such.
Thanks!
ZLM Posted - 05/08/2008 : 21:41:07
As long as it can be verified by the software, then the chip should be programmed correctly. IT seems your new version firmware is not the correct. How about try to program the earlier firmware version again on the same chip? It should work.
To add HY29FO40AC into library, add this line to the devices.txt:
Name="HY29FO40AC",ID="ADA4",Class="29F040B",Category="FLASH",MFG="Hyundai";
