 TOP2049 Will Not Burn CAT28C64
LJerni Posted - 05/11/2008 : 05:36:11
Anyone else having this problem? Will burn NM27C64's with no problem. Using latest software 3.27. Anyone have a work-around. Or know of different software that will work with this programmer?
simeon Posted - 05/18/2008 : 19:20:24
youll see v3.28 has better menus for ee/proms
still says 3.27 on there site ...though but the file is v3.28
and several changes perhaps a fix
try it out
i had to completely remove the drivers and app to get it to run properly
see the other post i made and how i removed the driver efficently
i notice you can do a no chip simuburn
with 3.28 it burns and varifys fine with no chip inserted
didnt try a blank test ticked
i think it must be an older usb driver in use issue with your install
for sure if your already using 3.28
