 Can't burn a HN27C1000G-10
scottwd Posted - 05/09/2010 : 11:35:54
This is my first time burning an EPROM. I read and saved the program from the old EPROM. When I try to burn the .bin to a HN27C1000G-10 I get the error:
Writing... Code
Elapsed time: 2.52 seconds.
Write failed, Address=0x000000, Buffer=0xF3 Device=0xFF
Write failed
Can someone help? Thanks!
ZLM Posted - 05/28/2010 : 09:21:16
Use:
Name="HN27C1000G",ID="0738",Class="HN27C101",Category="EPROM",MFG="HITACHI",RVpp="5V";
ZLM Posted - 05/21/2010 : 22:09:33
Thanks. I will check the chip and see if it is the HN27C101.
scottwd Posted - 05/18/2010 : 22:12:44
I finally got it working. I was trying 27C1000 and 27C1001 for a device type and it wouldn't return an ID. I tried HN27C101 and it returned 0738. I've burnt several chips now and they work great. Thanks EZoSat for making me check the chip ID. Hey ZLM, you will have one to play with and maybe this chip can be added to the device list on a future software update.
Thanks everyone!
scottwd Posted - 05/18/2010 : 08:19:27
I sent the chip today by Xpresspost. You will have it this week.
I will play around with burning it tonight.
ZLM Posted - 05/18/2010 : 07:25:13
The problem can be caused by:
1.chip problem
2.software bug
3.programm problem
4.pin contact problem
scottwd Posted - 05/17/2010 : 21:12:36
Sure. I will send it tomorrow to the address listed as the main office. Could I be doIng something wrong? It's my first time burning an EPROM but I do have an electronics background and I think I'm doing it right. Is there anything I can check?
ZLM Posted - 05/17/2010 : 19:42:36
Looks like a real one.
Are you able to send a testing chip to us? we can check and fix the problem.
scottwd Posted - 05/16/2010 : 19:36:47
ebay # 180496061198
h**p://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=180496061198&ru=http%3A%2F%2Fshop.ebay.ca%3A80%2F%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D180496061198%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
ZLM Posted - 05/16/2010 : 09:58:19
Searched interent, it seems no such HN27C1000G-10 EPROM.
Where did you get it? Fake chip?
scottwd Posted - 05/15/2010 : 12:05:55
Yes. It passes a blank check. I have since checked the supported device list and it's not in there. I'm not sure what the "G" is in the part number but I guess I bought the wrong EPROMs. Any ideas? Thanks
ZLM Posted - 05/15/2010 : 00:12:05
Did you do blank check before write?
The EPROM must be blank before write any new data.
