 HEX File Problem
enduo Posted - 01/03/2011 : 08:38:28
Hello everyone
I just moved from PIC16 to PIC18 but i came across a weird error while trying to transfer the HEX file to my PIC18F4520
The code compiles very well with mikroC but once i go to my programmer software (I am using USB PIC Programmer) i get this weird error that i don't understand
100.44 KB
The error appears after i load the HEX file, i did not press program and did not modify the fuses yet
Here is the HEX File contents:
:1000000044EF00F00000000075EF00F00000000079
:0A0010000000000000000000F3D71C
:10001C003F0E1B6E060E1C6E5B0E1D6E4F0E1E6E83
:10002C00660E1F6E6D0E206E7D0E216E070E226EFB
:10003C007F0E236E6F0E246E1B0EE96E000EEA6EA1
:0E004C001A50E926D8B0EA2AEECF00F01200D2
:10005A000900F5CFE6FF0006FBE10106F9E112000F
:10006A00086A080E0C6E003408360450085ED8B0D0
:0E007A0002D00826D89000360C2EF5D71200C2
:10008800186A196A6E0ED36E946A936A8190819287
:10009800C40ED56E640ED66EA00EF26E060E0B6EF2
:1000A800130E0C6EAD0E0D6E0D2EFED70C2EFCD75A
:1000B8000B2EFAD700000000192A1950640A01E132
:1000C800196A060E0B6E130E0C6EAD0E0D6E0D2E0C
:1000D800FED70C2EFCD70B2EFAD700000000ECD769
:0200E800FFD740
:1000EA0000C017F001C016F00CC015F0640ED66EF1
:1000FA00200EF26E181C016E01C018F00150000AA1
:10010A000DE181920A0E046E19C000F0A9DF00C049
:10011A001AF07FDF00C082FF81800ED081900A0E24
:10012A00046E19C000F09CDF08C000F000C01AF08D
:10013A0070DF00C082FF818217C000F016C001F094
:06014A0015C00CF01100CD
:020000040030CA
:0D000100021F1EFF8381FF0FC00FE00F40A4
:00000001FF
Please let me know if you have any idea what that is and how to fix it
Thanks in advance for all the help
ZLM Posted - 05/17/2011 : 09:19:34
The software can not parse that CFG line format correctly.
Beerwolf Posted - 05/13/2011 : 08:03:56
Hey ZLM, sorry to show my newbness :( I am having the same proble different code. You say to remove that line and set CFG bit manually. Could you explain a little more detailed.
ZLM Posted - 01/05/2011 : 00:10:47
This is a software bug I think.
remove that line and set the CFG bit manually.
