 93c46 rotated
M1DJF Posted - 02/15/2011 : 01:46:37
how can read rotated 93c46 on GQ4 programmers need this info as i am waiting delivery of my new programmer from mcumall,
as at present i am using willem programmer for which I had to make leads for 93c46 rotated could anyone shade some light on this matter as I use a lot of rotaded 93c46 soics.
thank you .
M1DJF Posted - 04/27/2011 : 23:59:33
here mate look at this curcuit diagram and you can make test clip which you can use with your programmer THE ONLY THING IS SOME OF THIS HAVE ROTATED PINS.
www.datasheetcatalog.org/datasheets/480/46331_DS.pdf" target="_blank">h p://www.datasheetcatalog.org/datasheets/480/46331_DS.pdf
benaknoun Posted - 02/22/2011 : 15:35:44
Hi, i also have GQ-4X and i am trying to read 93c46 rotated, can someone help me please? do i need to change the pin connections on the adapter?
Thanks in advance
benaknoun Posted - 02/22/2011 : 15:25:27
Thanks in advance
M1DJF Posted - 02/16/2011 : 00:51:53
thank you very much for your help
Originally posted by Bad_Ad84
Id just rewire the adapter and have one for rotated and one for normal.
I do not think the GQ-4X supports fully remapping each pin like a "professional" programmer can, therefore your adapter will need to match what the programmer expects - much like your willem programmed needed.
Bad_Ad84 Posted - 02/15/2011 : 04:45:06
