 M27C256B problems with enhanced willem
paulinho Posted - 09/22/2006 : 17:26:15
Hi...
I just bought one of this programmers and it reads 27c256 eproms ,but it canīt burn them, cause it gives an error and just writes the first byte.
Can anyone help me?
DL Posted - 09/28/2006 : 13:36:42
Originally posted by Murf928
I am having the same problem.
Mine reads: Error at 0x000000 Chip = 0xFF buffer = 0x81
Your problem is different. The EPROM isn't programming. What programmer do you have, what is the complete part number from your EPROM? What is VPP set to? Have you verified that VPP is correct?
HTH,
Dennis
DL Posted - 09/28/2006 : 13:35:09
Originally posted by paulinhoThe error is "Error at 0x000000 Chip=0x8A Buffer=0xAA"
This error means too many bits are being programmed in the EPROM. Changing programming timings is not likely to help.
0x8A = 0100 1010
0xAA = 1010 1010
The high nibble of the first address isn't being programmed correctly.
Do you get exactly the same error for all EPROMs?
HTH,
Dennis
Murf928 Posted - 09/27/2006 : 14:12:11
Any ideas?
Porsche 928 Supercharger Systems
paulinho Posted - 09/27/2006 : 04:52:54
Iīve done that now and it gives me the same problem.
Canīt make it doing any recording
What can i do now?
Thanks for the help - again
ZLM Posted - 09/26/2006 : 15:46:22
It seems you need adjust the tWp and tWc parameter.
Increse those two parameters.
Also, try to select 27256 from the software instead of 27C256. This will give more tWp and tWc room for adjusting.
Also, try to write more than once if first write attempt failed.
paulinho Posted - 09/26/2006 : 11:21:05
Thanks for the help,
But iīve bought 10 and all of them pass the blank check sucessfully (2 separate suppliers).
Read all chips.
ZLM Posted - 09/25/2006 : 15:55:30
Please provide exact error message.
Also, the chip need to be erased and pass the blank check before write new data.
