 Eprom of ECU for Peugeot 406 1.8l 16s
mirka66 Posted - 12/10/2011 : 08:35:29
Hi Guys,
Could someone tell me what this type of eprom is ?
52.66 KB
Car Peugeot 406 1,8l 16S - ECU Bosch MP5.1.1
in a forum post I found this
B58543 Eprom unknown 27C512 unknown
On GQ-4x With 27C512 device i can read it but with write error .
ZLM Posted - 03/13/2012 : 13:50:00
yes. All erasable EPROM has a glass window on top. Unless the chip is plastic and OTP chip, then is has no Window on top.
khaahk Posted - 03/13/2012 : 13:10:29
if it is eprom, it needs to be UV erased, before write.
the image shows an erase window on top of the chip?
ZLM Posted - 02/13/2012 : 20:43:26
Most of small 8 pin EEPROM chips have no ID. So, you are unable to ID those chips. Such as 93S46 and 24C04
benaknoun Posted - 02/04/2012 : 04:18:15
It may not be 27C512.
Use ID button to check the chip ID. It will report what is this chip.
Hi ZLM
just out of curiosity, i have tried this function "ID" on a 93S46 chip and it says "function not available for this device"
i have also tried it on other eproms like 24C04...etc and it says the same, is that normal ? is this function only available for certain chips ?
ZLM Posted - 12/12/2011 : 13:53:21
