 GQ-5X Universal?
Lookimback Posted - 07/05/2015 : 20:37:04
Wondering when there will be a 5X universal programmer with a 40 pin zif. I need one for NAND, but I need SPI too. I can't get both.
17   L A T E S T    R E P L I E S    (Newest First)
ZLM Posted - 03/16/2016 : 06:56:20
Yes.
The GQ-5X SPI has standard ZIF socket, you can use any standard adapters. Such as ADP-004, ADP-081, ADP-081A, ADP-098 etc.
service_repair Posted - 03/16/2016 : 05:40:38
Hi. a question, wanted to know if the gq-5x SPY. It works with the adapter
ADP-081 SOIC8-DIP8 adapter (~ 200mil) SA684.? and another question. Now Available gq 5x. universal?
service_repair Posted - 03/16/2016 : 05:39:40
ADP-081 SOIC8-DIP8 adapter (~ 200mil) SA684.? and another question. Now Available gq 5x.universal?
Thank you
ZLM Posted - 01/19/2016 : 08:58:40
Still under development. No exact date to release yet.
stevocz Posted - 01/19/2016 : 06:46:55
no info about release date?
stevocz Posted - 01/07/2016 : 23:44:38
when do you release GQ-5X universal? i must buy second programmer and i would like to have the new GQ-5x
ZLM Posted - 10/01/2015 : 07:07:10
not yet.
JimmerSD Posted - 09/30/2015 : 17:46:30
Any update on availability?
ZLM Posted - 08/25/2015 : 20:12:25
Yes. The GQ-5X Universal Programmer accepts all old version Willem and GQ-4X adapters.
Your programmer is GQ-5X SPI. In order to change the programmer from SPI to Universal, an universal top module needed. But this module is not available yet.
scubabobs Posted - 08/20/2015 : 10:38:57
Lets make sure we have this all straight. All your documentation I have read says that there is one base to which you change an adapter to convert a GQ-5X to either a SPI, NAND, or Universal. Your reply #4 above states that "GQ-5X Universal Programmer still accepts all adapters". Are these not true statements? Therefor there has to be an adapter to convert to a Universal version of GQ-5X. If this is false I need to return this programmer and purchase a GQ-4X that will work as advertised.
ZLM Posted - 08/19/2015 : 22:15:45
ADP-054 does not work with GQ-5X SPI. It will work with GQ-5X Universal. MCUmall is working on GQ-5X Universal, but do not have exact release date since there are more work need to be done.
scubabobs Posted - 08/19/2015 : 10:14:20
I now own a GQ-5X SPI. I am wondering what is the date when you expect to release the GQ-5X Universal? Also what addapter will I need to allow my 5X SPI to use my ADP-054 adapter?
Lookimback Posted - 07/13/2015 : 17:16:26
I just bought one from one of your eBay sellers. Thanks.
ZLM Posted - 07/11/2015 : 21:17:46
Sure. The GQ-5X Universal Programmer still accepts all adapters from old parallel Willem programmer and GQ-4X. Even more, the GQ-5X Universal also accepts other standard adapters from market or other brand programmer.
The software may be able to support both GQ-4X and GQ-5X Universal at same for a multitasking work.
Lookimback Posted - 07/10/2015 : 02:57:02
But, will my adapters from the 4X be compatible with the 5X?
ZLM Posted - 07/09/2015 : 11:13:09
Yes. GQ-5X universal will supports more chips than GQ-4X and even more flexible.
You can get both NAND and SPI top modules at same time. Then you have NAND and SPI programmer at same time using a single base.
coromonadalix Posted - 07/07/2015 : 17:55:37
If i understand corectly the GQ-5X universal will do everything that gq-4x does ??? plus added parts ??
