 AM29F100T problem
pichit10 Posted - 07/03/2020 : 02:43:32
Hello everyone,
I have problem with AM29F100T,ID check and write (Try with working chip,same issue)
I use ADP-003 V2.0 and V3.0 same issue,but working well with AM29F200B
Please advise.
Thank you,
Pichit
pichit10 Posted - 07/26/2020 : 21:14:01
Thank you ZLM
I get new lot ID 8040 (Not in library) all of lot(20 ea),Please advise again.Old lot device ID show FFFF may damaged
I've to edit device file,can delete,but can't write.
Thank you
ZLM Posted - 07/14/2020 : 22:16:24
If no pin contacting problem, then the chip may be a damaged chip.
