T O P I C R E V I E W
tinhead
Posted - 04/13/2009 : 02:26:33 For those who have issues with Top programmers and Vista :
The software is based on older WinDirver version. To fix the registration you will need a new wdreg.exe, wdreg16.exe and difxapi.dll. With wdreg.exe you can then register the driver ( even the older version which comes with Top software toghter ) - you might get some driver compatibility warrnings -so just accept.
Thats all - unfortunately i was unable to contact the Top developers - in principle they have only to replace the wdreg and include the difxapi.dll in their setup.
I'm personaly using wderg from WIndriver 9.21 - not sure if Jungo have issues on posting their executables, you might try the trial version to get the wdreg.exe and difxapi.dll
some additional info, in case you have already tried to install the drivers, you have to uninstall it, use command prompt, go to the top\drives directory and run:
Reconnect top2049 and start the software, it should work, if not replay all these steps, sometimes during the uninstallation one of the oemxx.onf files can be missing, so just copy then the whatever.inf into windows\inf directory - use the oemxx.inf missing name ...
Thats all, this has been tested few times already - unfortunately i have too many computers with Vista :)
And finally,it wors also with Windows 7 Beta, important is only to have the right one wdreg and difxapi.dll - the originaly included in top software are just too old and not Vista complaint.
For all who do updates of the top software regulary - it might better to install it in vmware/other XP box and then just copy the directorys over to the Vista computer ( to overwrite existing installation ) - or to run topwin5.exe /X C:\temp to unpack the files from installer, if you run directly the setup of the new version of software, the old included wdreg might destroy the registry , so you will have to uninstall/install like mentioned above manually ...
simeon
Posted - 06/10/2009 : 07:36:49 ps... dont forget to reduce usb port speed to 12mbps
and not use 480mbps max speed of usb 2.1 ports in most machines
either use usb 1.1 or use a hub for 12mbps in the middle
or face some chips not write but mostly read is ok
but reports say read can be an issue if you dont stick to 12mbps usb 1.1 top 3.xxx im sure wont suffer from this flaw in usb driver c++ directives not there
or more over top forget to add them to there usb driver implimentation
