T O P I C R E V I E W
firestarter
Posted - 04/02/2010 : 23:32:39 Hi, I'm new here and not a so-active-memory-burner. I got to write some 27c512, UV erased correctly, but it fail around 0x2yy address. Even trying slowest speed or any other. I think there's a problem around the USB 2.0 issue, as I read in this forum. After I've tried to resume the writing, past of the failure address and it works till completion. But this procedure I can't write the rest of the program as expected. Even the buffer will be modified and given the new start address, the burning will go on a wrong way
I didn't find much problems if writing Flash memory, they can go for most all of the speeds.
2 L A T E S T R E P L I E S (Newest First)
firestarter
Posted - 05/09/2010 : 07:28:49
quote:Originally posted by ZLM
I think it is a software problem.
I've installed Topwin 3.50. If there're chances to modify the configuration files, maybe I'll get better probabilities.
Posted - 04/05/2010 : 22:59:39 I think it is a software problem.
