 GQ-4X Hardware Revision
Malc Posted - 02/11/2013 : 07:07:05
Hi
I have owned my GQ-4X since 2010 and the hardware revision is: H/W Re: GQ-4X Re-1.30(SW Re. 6.21)
Is there an update to update the hardware revision ? I noticed while reading through this forum that some people have H/W Re: 2.10 and wondered what i'm missing
18   L A T E S T    R E P L I E S    (Newest First)
supervizeur Posted - 06/04/2017 : 09:10:55
We'll never know.
Probably.
anniel Posted - 05/29/2017 : 09:55:48
We'll never know.
supervizeur Posted - 05/29/2017 : 06:07:09
Curious too!
anniel Posted - 05/07/2017 : 09:41:52
Just out of curiosity, what is wrong with your unit?
phil789 Posted - 05/07/2017 : 06:51:37
ZLM i have sent you an email! asking for the newest firmware for my unit! :)
My current info:
H/W Re: GQ-4X Re-1.30(SW Re. 6.38)
USB Driver Re.2.0
Software Re. 6.38
Many Thanks..
ZLM Posted - 06/10/2016 : 15:08:19
Sorry for the late reply.
The 9332B has same pinout with 2532, except the pin 21 CS2 pin.
The datasheet does not have description of CS1 and CS2.
Try to connect CS1 and CS2 pins together while reading. If this does not work, then you can try to connect the CS1 to pin 12 (GND) while reading.
connect three pins together and select 2532 from GQ-4X software:
50399 bytes
joeb1355 Posted - 06/10/2016 : 11:43:52
Any update?
joeb1355 Posted - 06/02/2016 : 12:43:27
Your programmer firmware is fine. Do not need an update.
If the 9332B reading is not correct, then the software may need to be fixed.
Post the datasheet of 9332B, then I can check it for you.
I think this is it
h**p://www.datasheetarchive.com/dlmain/Databooks-1/Book241-577.pdf
The chips are very old from a pac-man arcade game circa 1980
9332B can be replaced with TMS2532JL -- which reads fine but all the 9332B chips read and the first 0x800 bytes are always FF -- I know the chips are good and work, just can read them properly in the burner
Maybe both CS1 & CS2 need turned on to read properly ?
ZLM Posted - 06/01/2016 : 23:36:14
joeb1355 Posted - 06/01/2016 : 18:41:34
Can I get the formware update?
My current info:
H/W Re: GQ-4X Re-1.40(SW Re. 6.38)
USB Driver Re.2.0
Software Re. 6.38
I hoping it will resolve reading 9332B OTP ROM chips -- they are 2532 compatible but whenever I read them the first half of the chip is all FF's
true 2532 eprom's read fine
ZLM Posted - 09/01/2014 : 09:09:59
most likely you do not need the new firmware. There are only very little changes and not in function.
taxdoru Posted - 08/31/2014 : 02:23:34
Can i get firmware gq-4x..!
niccowahyudi Posted - 08/14/2014 : 11:05:41
can i get firmware gq-4x..!
Bad_Ad84 Posted - 02/12/2013 : 23:45:08
The programmer software tells you, if you select a chip that requires higher firmware version IIRC
Malc Posted - 02/12/2013 : 05:34:02
Thanks that's good to know, " if it ain't broke don't fix it " my rule to :-) Is there a list that shows the required " firmware version " for each device the GQ-4x supports ?, In the device list i have it doesn't say anything about the required firmware version the GQ-4x needs to successfully program a particular device.
Originally posted by Bad_Ad84
The firmware update is sent via email. There is no need to return the programmer. Its just not available on the website - so only people who need it get it.
Flashing updates can brick devices, so its one of those "if its not broke, dont fix it". Only flash if you need the updated support of devices.
Bad_Ad84 Posted - 02/12/2013 : 00:56:09
Malc Posted - 02/11/2013 : 12:19:42
Thanks, Sounds like i'm not missing anything then, i'll leave as is though bit of a bummer not having easy access to hardware / firmware updates if needed, shipping and return cost's would probably be a tad expensive from the UK.
Cheers
Originally posted by craig6928
our is re-2.10 (sw re. 620)
and having lots of issues
the only way to get a hardware update is by them direct.
no downloads :(
craig6928 Posted - 02/11/2013 : 07:28:42
no downloads :(
