 en25qh64-104hip Not recognized...
F-bone Posted - 01/29/2016 : 09:18:47
Hi guys,
Is it possible to have an updated Devices list? I also have a cheap usb programmer and that one recognizes anything you throw at it!
Please consider this.
BR,
George
F-bone Posted - 02/09/2016 : 06:38:10
Add this line to your devices.txt
Name="EN25QH64",ID="1C7017",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Eon Silicon",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
great stuff, will do tonight. thanks anniel ;)
anniel Posted - 02/08/2016 : 08:04:40
F-bone Posted - 02/08/2016 : 07:30:49
It should work, it's the same chip but faster. What error do you get?
For the M48T86 yes it always get the data from the board but sometimes critical data is lost with the dead battery and needs to be reprogrammed in the new chip.
the error was ID for starters and then it would not verify.
anniel Posted - 02/08/2016 : 04:43:41
F-bone Posted - 02/08/2016 : 03:33:57
Did you try EN25Q64?
Did you resolved your problem in this topic?
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=6799
I tried that designation but did not work.
Regarding the other post, apologies I forgot to reply. Yes solved by replacing the chip. Data comes from the board.
anniel Posted - 01/29/2016 : 09:52:13
Generated in 0.3 sec. Snitz Forums 2000
