 GQ-4X4 Support for CY7C291A Reprogrammable PROM
GadgetFreak Posted - 10/28/2016 : 15:39:49
Can support for the CY7C291A UV eraseable 16Kbit PROM be addedx to the software?
Can it be done with a devices.txt line or will it need more work?
It is very much like a 12.5v programmable eprom so I think it should be fairly straight forward ;)
The data sheet can be is here https://4donline.ihs.com/images/VipMasterIC/IC/CYPR/CYPRS06053/CYPRS06053-1.pdf?hkey=EF798316E3902B6ED9A73243A3159BB0
or here:
Download Attachment:
275649
ZLM Posted - 10/28/2016 : 22:52:17
It needs more work.
The chip has three CS pins and need to take care separately.
You can build a adapter to take care those pins based on chip 2716 EPROM with 12V VPP.
Generated in 0.33 sec. Snitz Forums 2000
